1 105437 BIT Beta Team Jun 8, 2015 2,161 1,053 Feb 27, 2018 #1 How do I re-register my mobile device within the BI server so alerts will be pushed? Thanks
1 105437 BIT Beta Team Jun 8, 2015 2,161 1,053 Feb 27, 2018 #3 Thanks @fenderman... I went there and it already was listed. Do I have to remove it from there and then re-install the iOS app?
fenderman Staff member Mar 9, 2014 36,891 21,408 Feb 27, 2018 #4 105437 said: Thanks @fenderman... I went there and it already was listed. Do I have to remove it from there and then re-install the iOS app? Click to expand... make sure its checked...remove your old device...
1 105437 BIT Beta Team Jun 8, 2015 2,161 1,053 Feb 27, 2018 #5 fenderman said: make sure its checked...remove your old device... Click to expand... Thanks. Worked great!
