replace damaged female connector on a camera?
area651
Getting comfortable
Aug 18, 2018
473
410
San Antonio/McAllen Texas
When de-installing a camera from inside of a house, the connector was pulled off the camera pigtail and now I have a broken connector. Does anyone know what part I would use to replace this? This camera will forever be inside (its a free LAView fwiw) so I don't need it to be weather proof. I just need to be able to do POE.
Would I just use a keystone like this? Or is there a better soln?
Here's a pic of the damaged connector on the cam:
I replaced a damaged connector on a Hikvision camera once. I did use a keystone connector, and even though it was going into a junction box, just to be safe I wrapped it all up with Coax Seal. I've had no issues with it in the last couple of years since the repair.
ive done this once too. it works
You can use a punch down cat5 connector you will have to ohm out the pins to match your camera connector because the colors will not be standard colors for the punch down.
