I have Dahua NVR, nvr5216_5232-16p-4ks2 (I think 2017)
Something happend to NVR, and it will not power on. I looked into manual, there is no text about 'fuse' or anything. Google search also didn't return anything about fuse.
What optiond do I have, look for fuse, change power-supply or get a new NVR?
Which new NVR is a good replacement? I can really appreciate a quick answer. I can research, but a quick answer will be very helpful.
Current config.
NVR is connected to a router via ethernet.
I have Six DH-IPC-HDW4231EM-AS (POE) attached to it .
I have Two IPC-HDW2231RP-ZS (POE) attached to it.
I have two Amcrest.IP2M-841 (Ethernet) attached to it
I have one Amcrest.IP2M-841 (via wifi, wifi to router no to NVR directly)
I use IVR and motion detection on all cam.
I FTP the screenshots of motion from NVR to NAS.
I FTP the videos (motion detected video) to NAS.
NAS is connected to router to which NVR is connected.
Any NVR which is a good replacement?
Thanking you for helping me out on this.
Current config.
