Hi there,
On the front of my house I have two IPC-T2431T-AS, one looking left and one looking right. Nothing fancy to monitor, only who is walking over the lawn and who is parking on my drive-way. They work fine but I want to put them on another location and replace these two camera's with one dual-cam camera. I found the following options:
IPC-HDBW5441F-AS-E2
Advantage: price, fits existing PFB203W mount
Disadvantage: old model (?), dome, sensor
IPC-Color4K-T180
Advantages: EPTZ, sensor, turret model
Disadvantage: price, may not work with my NVR (DS-7608NI-E2 / 8P), which mount??
Do you have any thoughts about these 2 models or can you recommend me other alternatives?
Regards from the Netherlands
IPC-HDBW5441F-AS-E2
IPC-Color4K-T180
