Sorry this may get lengthy but it's a silly issue...
Have been using RLC-420 units for about 3 years with no problem. However as they are no longer available I have purchased a RLC-520. The problem is that when I log into it via a browser I cannot change the Network setting from DHCP to Static, I changed the IP Address to a valid open ip address and once I have completed the changes I click save and the message pops up and says "Failed"
Note image above with DHCP and an IP Address of 10.0.1.35
Note image above when trying to change to a Static IP Address of 10.0.3.39
I have already reached to Reolink support and while they have respond it is clear they have very little understanding of Networking as this was the latest response to the same questions above being posed to them:
"Thank you for your reply!
As before, Please notice that if you want to set the static IP address for the camera, the IP address for the first three-part needs to be the same. You can only change the last part of the IP address.
Like 10.0.1.XX instead of 10.0.3.XX.
Could you please try again? Thank you so much! "
I have tried through Google Chrome, FireFox and MS Edge (I also tried the old version of Internet explorer and the same result) I also tried Firefox in "Inprivate" mode.
I have very little confidence in getting a easy fix, I suspect the problem is built into the firmware itself. Somewhere between The RLC-420 and the RLC-520 line they seen have dumbed down the network support.
Anybody run into this issue?
- I can only create a Static if I use the same DHCP assigned IP Address of 10.0.1.35 (absurd)
- I have confirmed Multiple Times that the IP Address of 10.0.3.39 is valid and not in use. (and I also tried 10.0.3.45)
- I already know that the IP Address Scheme is valid and ranges 10.0.0.1 - 10.0.3.254
- I have at least 30+ RLC 420 units using IP Address specifically in the 10.0.3.xxx portion of my network
