mat200
- Jan 17, 2017
- 18,519
- 31,047
Unfortunately price is a serious consideration, especially as we're down South... where the exchange is not in our favour and human life doesn't have much value either and where criminals ain't caught or simply let free.
The purpose is primarily to alert rather than identify. The simple logic of fleeing, arming or assisting rather than identifying the aftermath, which is always the same ...
Motion detection with Deepstack analysis followed by alerting is critical.
I expect the first reply to be: "You can't put a price on life, buy the best". But that is not reality and others would then rather go without. ie. Think of $140USD converted to $2280 and you only earn $10 000.00 per month (120 000/year) of which you need at least 8 cameras to cover all areas. Would that still be affordable...
The quest is therefore for the cheapest POE IP cameras that supports an iframe & fps ratio of 1.0 and will work solidly with BlueIris&Deepstack.
Hi @Peek
In the USA the current 5MP Amcrest turret and bullet models are a lower cost model which follows standards ( they sell for $50-60, however their bodies are not all metal .. )
You can check with Andy here ( Empiretecandy ) and see what he may have available to your country.
In general Hikvision and Dahua OEM cameras meet standards well.
ideally getting larger sensor cameras will serve you better for quality image capture.
Remember to check the DORI section of the cliff notes.
