Video in question:
Spoiler - graph of failure rates:
Why is quality important?
Also a mention about divided opinions on various forums.
This video gives numbers on failure rates and opinion. Numbers don't lie unless they are a lie.
A summary and quoting his opinion for each brand:
Reolink:
But he does not purchase anymore given his bad experience with them.
Hikvision:
In his experience, he seems to like them and finds them reliable. Downfall being that these are not NDAA compliant.
Amcrest (OEM of Dahua):
Important in this case is that a seal is not electrical, it is something any brand (including Axis, Avigilon, etc) could suffer a fault from.
Strangely, He has not mentioned about Amcrest being a Dahua OEM and Dahua being banned under NDAA. Yet he has avoided Hikvision because of NDAA compliance.
He mentioned a big reason they use Amcrest is because the camera's AI/IVS works with Synology surveillance station well.
Synology cameras:
A mention he has tested Synology cameras and thinks they are good quality but has not run them for a long time to compare against what else has been said.
Ubiquiti cameras:
Why does this information relate to an end user installing cameras?
It's real world experience!
It's not a sponsored video by a camera novice who has very little knowledge about the subject.
When you talk about the way we have to deal with installs, is we may have to rent a lift, ladder and sent a crew out there.
There's a lot of labour involved.
You only want to ever install them and let them work over time for at least 5 or 6 years before you expect any degradation or problems.
Reolink:
He then mentions that he has not bought a camera since 2020 and maybe they have improved.They didn't hold up, 68 Reolinks and 6 died over time.
Hikvision:
Of the 64 Hikvision cameras we bought..... actually zero have died.
We haven't had a single call about them failing and that's kind of impressive.
Hikvision makes a decent camera if you are looking for home use. (an installation not governed by NDAA compliance)
This is mentioned as a dome camera failing for water ingress and mentioned it could be installer fault or just a bad factory seal.Out of 165 Amcrest cameras, a single one died.
Synology cameras:
Ubiquiti cameras:
Then said there is a low failure rate without specifying how many installed and how many of those failed.We used to install a lot of Ubiquiti systems, we don't install many anymore.
But I think it's a good platform, it just locks you into their ecosystem.
