Reolink Duo / Dual-Lens 150° FOV, 4MP/2K : review of nighttime image captures by securitybros
mat200
17,461
29,433
securitybros on Youtube reviewed the following on Sep 18, 2021
REOLINK PoE Security Camera Outdoor System, IP Camera with Dual-Lens 150° FOV, Smart Human/Vehicle Detection, 4MP/2K Color Night Vision, Two Way Talk, Up to 256GB Micro SD Card, Reolink Duo PoE
I will take a few screen shots of some key image captures for illustrative purposes .. I do not plan to review his entire commentary. ( note, often I have posted similar Reolink topics in the Chit Chat section .. feel free to search for more of these .. )
ref:
update:
One of the main Reolink threads here:
Night time, low light with IR ..
Notice moving objects vs still objects .. can you read what is on his shirt ?
Spot light turns on ..
Back to IR mode ..
Reolink, once a POS always a POS.
The biggest issue I have with this camera is that there is no benefit to this vs a dual sensor camera like the 'boobie cam'.
Look at each camera angle, those are awful angles with soo much space wasted. Better off buying a dual sensor camera where both cameras can articulate for a better viewing angle.
The Hikvison/Dahua version at least stitches the video together to make it worthwhile being two imaging sensors at fixed angles.
Painful....lost one of his feet and most of his leg here:
As always, thanks for taking the time to dissect these!
And wow that has to be some of the worse color static images we have seen recently from a Reolink. Usually their static image is good, but the motion is poor at night. That just looks horrible.
Great captures as always. A picture speaks a thousand words
Hi Mark, are you referring to this? IPC-HDBW5441F-AS-E2
So one using BI could get a single stream with a combined video from both lenses?
That camera is two individual streams. That is logical because the lenses are not hard fixed into position.
I'm comparing to the new [Hikvision] DS-2CD2T87G2P-LSU/SL and [Dahua] PFW5849-A180-ASTE which is a fixed position dual lens camera like the Reolink Duo.
This is the Dahua version which stitches the video into one:
Bullet 180 degress camera is out now.
(Photo from @EMPIRETECANDY )
1659922955756-jpeg.135845
So which one of these dual cameras works best in BlueIris? Was looking at installing one infront. Was eyeing the hikvision ds-2cd2387g2p.
Hi @T_Tronix
The Dahua OEM or Hikvision OEM models should work better by significant margins vs Reolink ..
Do you think the new Reolink Duo 2 give the same issues?
Reolink are made to consumer grade and a cheap price.
Basically everything they make is cheap quality.
Reolink still puts in small sensors .. so yes I do expect issues ..
