- Jan 17, 2017
- 16,131
- 27,099
Executive Summary:
DO NOT be a sheep. Ask what a reviewer can be missing, ask if a reviewer is using hype words to sell the cheapest product.
Finding the BEST 4K Security Camera NVR Package (Reolink vs Amcrest vs Swann)
The Hook Up
4:30 - Mentions Blue Iris "NVR" interface is much better but probably not $600 better
Response: Many members here go with a good used i7 Business Class PC and save a lot on that. ( some getting a good PC for $200+/- and also getting a decent PoE switch ) - so it may cost a bit more than an NVR in a kit, but for many here they really like Blue Iris and feel it is worth it. ( note, if buying an NVR separately - it can cost more than going Blue Iris + used business class machine )
11:10 - "let's check out the daytime clarity of each camera"
this is the section which I feel is very poorly laid out.
Reviewer tests a image capture at 25ft of text.
Fact: Wider FOV = less pixel density at 25 ft.
Fact: Tuning parameters also matter.
Reolink B800
Image Sensor: 1/2.5" CMOS Sensor
Effective Pixels: 3840x2160 (8.0 Megapixel)
Lens: f=4.0mm F=2.0
Angle of View: Horizontal: 97° ; Vertical: 51°
ref:
reolink.com
Amcrest Camera IP8M-T2499EW-28MM
Image Sensor 1/2.5” 8Megapixel progressive scan CMOS
Focal Length 2.8mm
Max. Aperture F1.6
Angle of View H: 112°, V: 69°
ref:
amcrest.com
and
The reviewer FAILS completely to mention FOV and Lens ( 4mm vs 2.8mm ) in his comparisons - which in my book is completely misleading.
11:49 - "night 25 ft."
".. results were very similar..." again testing an image capture at 25 ft of text.
claims the other cameras have very poor night time performance.
Again major FAILURE on the reviewer.
Failed to test moving subject.
Failed to even mention lens differences.
Failed to even mention FOV differences.
12:12 "..reolink seems to have really perfected their algorithms check out this image from 10 feet away the Reolink imagine looks almost fake but it's just a result of their specific post processing .. "
"... Reolink the results are amazing..."
This is complete BullSh-t. So you're telling me Reolink which uses cheaper processing, has less engineers doing R&D is gonna beat Hikvision and Dahua?
This review is a dangerous one, full of misinformation and omissions. It is not a honest review by any measure, and all the thumbs up on the video are from people who do not know they've just been had by omissions of facts and failure to do a proper review.
This reviewer did such a frame up of the competition and failed to test any moving objects at night ( Reolinks major downfall ), that I highly suspect he is on Reolink's payroll.
Update:
At first the review looks legit, until you notice he compares are 4mm lens Reolink vs a 2.8mm Amcrest ( Dahua OEM ) and claims the Reolink is amazing "..reolink seems to have really perfected their algorithms check out this image from 10 feet away the Reolink imagine looks almost fake but it's just a result of their specific post processing .. ... Reolink the results are amazing..."
when the simple truth is he is comparing a 4mm lens vs a 2.8mm lens.. nothing amazing, just reducing pixel density for a wider FOV.. simple math stuff...
- Test your cameras and kits right away.
- Just do a bench test.
- Test real world conditions.
- Test moving suspects.
- Test at night, test at day.
- Use a test rig to place cameras at positions which you plan to place the cameras.
The Hook Up
Reolink B800
Lens: f=4.0mm F=2.0
ref:
Reolink B800 | 4K Ultra HD Outdoor PoE Security IP Camera | Reolink Official
Meet Reolink B800, the state-of-the-art 4K 8MP Ultra HD outdoor/indoor bullet PoE IP camera, equipped with enhanced night vision, audio recording, motion alerts, remote live view, weatherproof, etc.
Focal Length 2.8mm
Max. Aperture F1.6
ref:
Amcrest UltraHD 4K (8MP) Outdoor Security IP Turret PoE Camera, 3840x2160, 164ft NightVision, 2.8mm Lens, IP67 Weatherproof, MicroSD Recording (128GB), White (IP8M-T2499EW-28MM)
Amcrest UltraHD 4K POE Turret IP Security Camera / 8-Megapixel 3840x2160 / 164ft Night Vision / MicroSD Recording / Metal Housing / IP67 Weatherproof / 2.8mm Lens / FOV 112° / IP8M-T2499EW-28MM (White) CAMERA FEATURES : EXPERIENCE ULTRA HD 4K – Stunning ultra-high quality 4K (8-Megapixel /...
Update:
