TL1096r
- Jan 28, 2017
- 1,211
- 472
blue iris cannot adjust frame rates using the fps setting- if it did it would be pointless because it would toss frames and you would get no benefit.. ...you MUST set it in the camera/NVR...in blue iris it is simply a reference that auto adjusts..
Yes, got it done through NVR, picture looks a bit more blurry, still choppy though even at 16fps.
And what setting is the reolink software most likely using that it can produce a clean picture and no lag/choppiness vs bi, I know it is most likely not BI but anytime I change a setting a new result happens so I feel it could be the settings I'm messing with through BI also.
