ReoLink Battery
goneracin
Getting comfortable
Jul 2, 2023
194
411
On the Range
The ReoLink thread has grown so much, i was hoping to get a battery version stand alone thread?
I have 2 issues.
1)i cant get it into BI. My router assigns it an ip that is under the routers umbrella like my 3d printers and everything else.
2)it loses signal constantly. I have it a little way from the router and maybe thats it, ill move it later, although i cant imagine its better when its outside?
on my pc it wont reconnect unless i hit the play arrow. My phone sometimes it comes back, sometimes not.
the lay my house is, its going to be a pain to run cat5, but if thats a necessary evil so be it
if you would prefer to keep this in the other thread, im happy to move it there. Searching is a bit harder. Seems the batter version has its own gremlins
Does it have a webGUI or can you use Reolink's client program to log into it ? If so, assign it a unique static IP in the same subnet as your BI server but outside of your router's DHCP pool. Enable RTSP and ONVIF also.
My 2 Wi-Fi Reolinks DB's are on dedicated wireless 5GHz AP's and work wonderfully through brick; both are under 12 feet from those AP's.
