Did you try the Pro (paid) version of Tinycam?Tinycam dont work good, vlc can play, vbut i dont find a way to play multiple streams at oce.
RTST link don work on my cam, only RTMP.
Are you using the regular version or the paid version?i try but this dont work on my firestick. funny shooter 2
i usually use free version and it works absolutely fine, should i use paid also ?Did you try the Pro (paid) version of Tinycam?
It will stream RTMP and work with FireTV and Firestick. удалить фон из фото
IMO, the only reason to purchase Pro would be if you wanted one or more of the features available on Pro that is not included with Free, such as the Internal Web Server or being able to stream using RTMP (Free has no internal web server and won't work with RTMP).i usually use free version and it works absolutely fine, should i use paid also ?
Thanks bro i appreciatedIMO, the only reason to purchase Pro would be if you wanted one or more of the features available on Pro that is not included with Free, such as the Internal Web Server or being able to stream using RTMP (Free has no internal web server and won't work with RTMP).
A list of features included with Free versus Pro can be found here. image remover online
Yes, it should be possible, but Kodi may need a workaround since the standard RTMP playback setup usually opens each stream separately. You could try using a Kodi add-on or a multi-view/video-wall solution that supports two simultaneous streams. If your Firestick has enough processing power, both Reolink feeds should be able to run side by side.I want to watch my 2 reolink cams on firestick. I managed to watch from rtmp code on Kodi, and it works good.
But i want to watch 2 in same time on split screen, is there any way to do this? wayin ai
