P priobe n3wb Jan 29, 2017 14 5 Mar 10, 2024 #1 Hello I hope this is the correct place to ask this question. Is there a way to remove the mounting base of the IPC-B52IR-Z12E S2 camera. I would like to mount it using some other method. Thanks
wittaj IPCT Contributor Apr 28, 2019 32,895 62,952 USA Mar 10, 2024 #2 What do you mean? You simply unscrew the locking screws on the underside of the mount and it comes off. Reactions: JDreaming and looney2ns
P priobe n3wb Jan 29, 2017 14 5 Mar 10, 2024 #3 It does not completely come off. the cable has a big ferrite core on it and it will not fit through the mount to take it off completely Last edited: Mar 10, 2024
wittaj IPCT Contributor Apr 28, 2019 32,895 62,952 USA Mar 10, 2024 #4 It had been so long and went and looked at mine - I had to cut it off and re-terminate a new connection on it.
P priobe n3wb Jan 29, 2017 14 5 Mar 10, 2024 #5 wittaj said: It had been so long and went and looked at mine - I had to cut it off and re-terminate a new connection on it. Click to expand... Thanks
guykuo Getting comfortable Jul 7, 2018 767 2,344 Sammamish, WA Mar 10, 2024 #6 With this, all modifications are possible. Reactions: looney2ns and JDreaming
