Hi all,
I recently setup a new Dahua NVR 4208 model. I can remotely view via iDMSS Lite or Easy Viewer Lite but no through Guarding Expert for some reason. Cam Model IPC-HDBW4431F-AS all purchased from Andy.
I have 8 different retail locations and i have various NVR's through my stores including LTS, HIK-Vision, and one from Nelly Security. They all work with Guarding Expert, i like that app as the image shows much clearer than on iDMSS Lite with the same substream settings and similar (4MP Cams) Arguably the cams from Dahua are better quality and newer but for some reason the substream looks like my old 600TVL CCTV.
Settings for substream are set to
D1
H264
10 FPS
VBR - GOOD
768 Bit Stream
Below i have posted 2 pictures, 1st is Dahua NVR, other is my HIK-Vision. Same Substream Settings
Thanks in advanced,
Danny
l,
D1
H264
10 FPS
VBR - GOOD
768 Bit Stream
- Does the app make that much of a difference in how the image looks?
- Why wont the same exact settings from iDMSS work on Guardng Expert
- If you could reccomend a different app that is better i am all ears.
Thanks in advanced,
Danny
l,
