I have 3 cams currently monitored with ISPY. all working fine.
2 cams from China &1 EASY N
They are on rental property I own 30 miles from home.
they are all behind a firewall with a POE Switch.
Here is the problem I am having with Blue Iris
When I try to install a cam from home it "finds & inspects" only one cam. all the ports are different and when I say go to port 62, it inspects the cam, says it is done , but in the end it loads a cam on port 90.
if I turn of port forwarding for port 90 then it will load the cam on port 62 but as soon as I turn on the port forwarding for that port the cam reverts back to port 90.
each cam has a different RTSP & ONVIF port.
hope this make sense.
