Hi,
I'm trying to use PC-NVR of smart pss for recording my cameras stream.
The smart pss and PC-NVR located on local pc and my xvr(nvr) located remotly at my store.
Currently, i added all devices using their S/N - Dahua P2P and i can indeed watch a live view and get events alerts.
I created a PC-NVR with my local ip and port 37777 (ip and port are determined by the smart pss).
When i try to select a channel for recording, i see no channels.
I believe that the PC-NVR look for local devices, hence doesn't shown any.
Is that right?
Can pc-nvr woks with P2P connection?
Second, i wonder whether a vpn connection (as opposite to P2P) will show my remoted camera as they are local.
By that i will be able to see the camera channels and i will be able to finally record them.
Is that right?
