Hello all,
Could you explain me how I can disarm my Dahua survilance system remotely ?
I usually use the next way to do this.
When I go to the home I go inside where is my NVR located and using a mouse switch off the smart plan for each camera connected to NVR.
The problem is that when my car is driving home area the IVS rules start to work and they turn on alarm lights.
It is very uncovinient.
Is the way remotely using mobile GMSS application to switch off survilance alarms or there is another way?
Could you tell about how you disarm yours survilance system when you are getting home?
