I am able to connect to BI with my Samsung when my PC is hardwired to my router. When I disconnect the Ethernet cable and use WiFi, I am not able to connect. When I check the port on CanYouSeeMe.org, it can see the port when it is connected directly to the router with the Ethernet cable. When I disconnect the cable and connect using WiFi, I get the message "I could not see your service on xxx.xxx.xxx.xxx on port (81) - Reason: Connection timed out.
Any sugestions to to resolve the issue? Thanks!
