I've been using BI for a couple of weeks tweaking settings to prevent false alerts. Now I've moved on to trying to get remote access to work and I'm stumped. When I try to connect using the BI machines external IP I get a connection timeout error.
- I have the BI web server enabled to use port 8888
- My router is configured to forward port 8888 to my BI machine
- I've used Port Forward Network Utilities on the BI machine to verify the port is open. I did have to disable the BI web server before this utility would work so I think that verifies that the BI web server is listening on port 8888
- I can connect to the BI web server from a LAN machine using the BI machine local IP and port 8888 but not using the BI machine external IP
- I have Windows Firewall disabled.
I think everything is configured correctly and yet I can't access the BI web server using the BI machine external IP either from within the LAN or from an external machine.
I would so appreciate some troubleshooting help!
