The idea is to be able to access the cameras remotely on my iPhone (via the BI app) while also isolating all cameras and BI server away from my home network. In the event of a worst case scenario, I want to ensure that if the BI server gets compromised, at least everything else on my home network won't be under threat.
Just wanted to check whether the below setup will work before I purchase the hardware required.
Questions:
- Set up a BI server with dual NIC (NIC-A will have Internet access and NIC-B will not)
- Connect cameras to an unmanaged TP-link POE switch which then connects to NIC-B
- Assign static IP to all cameras with random gateway ranges
- Connect NIC-A to a VLAN port on the router (Dream Machine)
Questions:
- Should I opt for a managed switch to connect the cameras and create an additional VLAN?
- Should I add any necessary firewall rules on the router?
- Rather than connecting NIC-A directly to the router, should I connect to the home switch (in a separate VLAN) which then connects to the router? Would this bottleneck the network?
