Hello all
A colleague of mine who had also had his work truck broken into decided to install some IP cameras to watch his truck. As he was incredibly computer unsavvy, he opted to go with a Hikvision NVR off Aliexpress along with 3 DS2432F cameras. To his credit he's gotten all the cameras mounted, run the CAT6 droppers back to his study and connected to the NVR. He's also setup the NVR for record on motion detection. I gave him a hand the other night to setup the remaining things such as emailing out on motion recording and remote access. His iPad on the home wifi is able to connect to the NVR using Hikvision iVMS-4500. Now this is where it went a bit askew. His ADSL connection goes through a D-link DSL-G604T ADSL wifi modem router. I'd setup the port forwarding of ports 80, 8000, 554 and 1024 to his NVR IP address. I'd also tried setting up ddns with HikDNS as well as dyndns.org and also the IP address directly but can't for the life of me access the NVR. A couple of things which I'm not too sure of and still need to confirm is whether his ISP allows incoming connections or whether port forwarding is working on his modem/router.
Was just wanting to know if anyone else has had an success with access a Hikvision NVR remotely?
Thanks in advance.
Thanks in advance.
