Remote access issue with BI 6
AGI
Oct 26, 2018
7
1
Luxembourg
Since I upgraded my Blue Iris from v5 to v6, remote access works for a couple of hours after having (re-)started the PC (or having restarted the service (I run BI as a service)), but then stops working.
Rolling back to v6.0.2.10 doesn't solve the problem.
The Windows Defender Firewall allows inbound traffic for "C:\program files\blue iris\blueiris.exe" on all TCP and UDP ports for domain, private and public networks.
Remote access is configured via a Traefik reverse proxy (that worked without issues with v5), forwarding traffic from to my BI PC on .
Remote access to other sites proxied via Traefik is working fine.
The following restrictions are configured in Traefik:
Code:
default-headers:
      headers:
        frameDeny: true
        browserXssFilter: true
        contentTypeNosniff: true
        forceSTSHeader: true
        stsIncludeSubdomains: true
        stsPreload: true
        stsSeconds: 15552000
        customFrameOptionsValue: SAMEORIGIN
        customRequestHeaders:
          X-Forwarded-Proto: https
Is one of those perhaps too strict with v6 ?
Otherwise I'll just have to roll back to v5 ... :idk:
@AGI Check your Blue Iris log file for clues as to why it stops working. Since you're using a reverse proxy in front of Blue Iris, you may want to add its IP in Blue Iris's "Limit access by IP address" box as always allowed (e.g. +127.0.0.1).
@Techie007L didn't really explain why it is happening. The theory is that you could be getting burned by Blue Iris's new "security" features which automatically ban IP addresses suspected of being unwanted automated traffic. You can search the Blue Iris 6 changelog for the word "ban" to find mentions of the stuff that was added in late February and early March.
It is very poorly documented, but basically, Blue Iris now automatically bans IP addresses that are believed to be sending unwanted traffic.
Blue Iris will ban an IP for:
  • Making a request with an unrecognized or missing User-Agent header. This can be configured in Blue Iris Settings > Web server > Advanced.
  • Requesting certain URLs often requested by vulnerability scanners, but not by legitimate Blue Iris client traffic (like /.env or /cgi-bin). This is not configurable.
  • Possibly other things, I'm not sure. As I said, it is very poorly documented.
If your proxy server is publicly accessible (especially on TCP 80 or 443), then it will be carrying this kind of automated traffic frequently.
Early implementations were highly problematic, banning basically all third-party integrations and reverse proxy servers that happened to carry a web request Blue Iris did not approve of, and not logging things properly.
However since about BI 6.0.3.8 (or newer), Blue Iris should not be banning any IP addresses it thinks are "local" or "LAN". We don't know for sure which addresses those are; whether Blue Iris looks at your network interface subnets or uses hard-coded "private address" lists or is IPv6-aware. It is all unknown. To be safe, you should whitelist the addresses your Traefik server might use in Blue Iris Settings > Web server > Advanced > Limit access by IP address, with a preceding plus sign as noted by @Techie007L. If there are any addresses you do not recognize in the "Limit access by IP address" box, delete them. They could have been added by one of the problematic BI versions. You can also empty out the "Ban user-agents" textbox if you want.
I don't really know what the intent was behind these so-called "security" features but it probably had something to do with people finding a bunch of unrecognized addresses in their Blue Iris Status > Connections window and opening support tickets about it. Because these "security" changes do nothing to help with real security threats.
There's also a BI web server advanced setting, "Use X-Forwarded-For, X-Real-IP" which can be helpful if you set it up correctly because it will allow Blue Iris to identify the real client IP address from behind your reverse proxy server(s). But don't enable that checkbox if you don't know how to configure BOTH of those headers in your reverse proxies, otherwise you could actually be opening the door for hackers to easily spoof those headers.
@Techie007L @bp2008 Many thanks for your help and insights, this is very useful.
Following your advice, I did the following and it works up till now:
Well ... I cheered too soon. I still have the same issue. Remote access works for some time (it may be an hour, sometimes several hours) after having restarted the Blue Iris service and then stops working.
When remote access works, the Blue Iris log shows:
Code:
10    06/05/2026 23:24:40.118    Server                  [::ffff:192.168.99.247]: Connected
10    06/05/2026 23:24:40.192    admin                   [::ffff:192.168.99.247]: Login
10    06/05/2026 23:24:46.700    admin                   [::ffff:192.168.99.247]: Logout, 0:06
192.168.99.247 is the Traefik proxy server.
When remote access doesn't work, I can't find anything in the Blue Iris log.
In Traefik, when remote access works, the access log shows:
Code:
{"ClientAddr":"[IP address]:12044","ClientHost":"[IP address]","ClientPort":"12044","ClientUsername":"-","DownstreamContentSize":2844,"DownstreamStatus":200,"Duration":12658508,"OriginContentSize":2844,"OriginDuration":12302960,"OriginStatus":200,"Overhead":355548,"RequestAddr":"blir.mydomain.com","RequestContentSize":62,"RequestCount":21617,"RequestHost":"blir.mydomain.com","RequestMethod":"POST","RequestPath":"/json?random=1778102336428","RequestPort":"-","RequestProtocol":"HTTP/2.0","RequestScheme":"https","RetryAttempts":0,"RouterName":"blir@file","ServiceAddr":"192.168.178.28","ServiceName":"blir@file","ServiceURL":"https://192.168.178.28","StartLocal":"2026-05-06T23:18:56.97984023+02:00","StartUTC":"2026-05-06T21:18:56.97984023Z","TLSCipher":"TLS_CHACHA20_POLY1305_SHA256","TLSVersion":"1.3","entryPointName":"https","level":"info","msg":"","request_User-Agent":"okhttp/4.9.3","time":"2026-05-06T23:18:56+02:00"}
When remote access doesn't work, the Traefik access log shows:
Code:
{"ClientAddr":"[IP address]:13133","ClientHost":"[IP address]","ClientPort":"13133","ClientUsername":"-","DownstreamContentSize":11,"DownstreamStatus":502,"Duration":1036647095,"OriginContentSize":11,"OriginDuration":1004100700,"OriginStatus":502,"Overhead":32546395,"RequestAddr":"blir.mydomain.com","RequestContentSize":0,"RequestCount":21578,"RequestHost":"blir.mydomain.com","RequestMethod":"POST","RequestPath":"/json?random=1778101849715","RequestPort":"-","RequestProtocol":"HTTP/2.0","RequestScheme":"https","RetryAttempts":0,"RouterName":"blir@file","ServiceAddr":"192.168.178.28","ServiceName":"blir@file","ServiceURL":"https://192.168.178.28","StartLocal":"2026-05-06T23:10:50.407923238+02:00","StartUTC":"2026-05-06T21:10:50.407923238Z","TLSCipher":"TLS_CHACHA20_POLY1305_SHA256","TLSVersion":"1.3","entryPointName":"https","level":"info","msg":"","request_User-Agent":"okhttp/4.9.3","time":"2026-05-06T23:10:51+02:00"}
The 502 code indicates an issue with the Blue Iris webserver, right?
I found in the logs that Blue Iris is banning my Traefik proxy (192.168.99.247), despite it being explicitely allowed under Settings > Webserver > Advanced.
Code:
10    17/05/2026 05:28:52.961    Server                  [::ffff:192.168.99.247]: Connected
10    17/05/2026 05:28:52.961    Server                  Banning [::ffff:192.168.99.247]: bad URL match ".env": /.env
10    17/05/2026 12:56:22.874    Server                  [::ffff:192.168.99.247]: Connected
10    17/05/2026 12:56:22.874    Server                  Banning [::ffff:192.168.99.247]: bad URL match "robots.txt": /robots.txt
Is this a bug or am I overlooking something?
Reactions: Techie007L
Im back here just searching around to see what the latest news on this reverse proxy issue is, I've had these same issues with any new version I try after 6.0.2.10 almost to a T. I'm behind an Apache reverse proxy. If i restart service might work for an hour. If I whitelist the Apache server it still happens. I think I have checked and unchecked everything anywhere in the new settings. I've tried just about every release of BI and they all have done it post 6.0.2.10 in my case 6.0.2.10 always lets it work. It has to be something in the ban user agents settings, although it even happens when its blank. Its the only thing that is different about these "settings" version to version that is obvious.
The latest I have confirmed to still have, at least my issue, is 6.0.6.9 and today 6.0.7.0 is out and im not even going to bother. 6.0.2.10 is working. I've seen others have success post 6.0.2.x., but in my scenario new versions of BI dont like a simple Apache reverse proxy for some reason. I did explicitly add the following into my virtual host file, but it should be passing by default.
Code:
RequestHeader set X-Real-IP %{REMOTE_ADDR}s
RequestHeader set X-Forwarded-Proto expr=%{REQUEST_SCHEME}
Im not sure. Waiting, ill keep trying.
This issue doesn't seem to be high on the developers priority list, unfortunately. I have already posted what appears in the logs (unless there is a way to make them more verbose).
As I didn't manage to sort out the issues with my proxy server being banned for whatever reason and with the new security features of BI6 being so badly documented, I finally gave up and switched to Unifi Protect. Honestly, I'm not looking back: remote access works hassle-free and my Axis cameras work just fine with the ONVIF support that was recently added and the possibility to make them AI capable with an AI port.
I can't blame you at all, honestly. Having your remote access experience wrecked like that in the name of security is not a good tradeoff even if it works. Which it doesn't. Because the type of automatic traffic those features ban never was a threat to Blue Iris's cybersecurity in the first place.
It is possible that implementing the X-Forwarded-For and X-Real-IP headers was the last missing step to clue Blue Iris in to the fact this IP was a reverse proxy server that should never be IP banned. I didn't see your earlier replies until now, sorry!
But the fact is, those steps never should have been necessary in the first place. The auto-bot-banning features only real value is to reduce the amount of rows people see in the Status > Connections window, which in theory reduces support emails to the Blue Iris developer. It is not worth disrupting legitimate user traffic for. And I believe I told Blue Iris support this right after they began implementing these features. Goes to show how important my opinion is I guess.
Reactions: gwminor48 and TonyR
Brian,
I wish Ken / Blue Iris would pay more attention to you in several categories regarding BI, as your experience and expertise speaks for itself. As they rightfully say, "You can lead a horse to water but......." :cool:
