mat200 IPCT Contributor Jan 17, 2017 16,316 27,367 Wednesday at 7:48 PM #1 Remember to check the specs carefully, as often it is not listed as a main part of the description. For example, a deal from Woot .. you had to hit the specs to see the CCA ( Copper Clad Aluminum ) specs. Reactions: TonyR, Broachoski, dudemaar and 1 other person
J johnfitz Getting comfortable Feb 4, 2021 886 917 NY Wednesday at 7:54 PM #2 Yea, I made this mistake years ago when I wired my 9 cameras.... wasn't aware then... I've been lucky so far, haven't had any issues (yet) Reactions: mat200
T tigerwillow1 Known around here Jul 18, 2016 4,812 10,958 USA, Oregon Wednesday at 9:10 PM #3 In a 20+ year old copy of the TIA/EIA 568 spec it says: "The cable shall consist of 22 AWG to 24 AWG thermoplastic insulated solid conductors that are formed into four individually twisted-pairs and enclosed by a thermoplastic jacket." Was the standard relaxed to include CCA cables.? If not, I interpret it as disallowing CCA, making advertising CCA as cat6 to be false advertising. Future Cable says more or less the same thing here https://www.truecable.com/blogs/cable-academy/the-ansi-tia-568-series-of-specifications-what-is-most-important-to-know-for-copper?srsltid=https://www.truecable.com/blogs/cable-academy/the-ansi-tia-568-series-of-specifications-what-is-most-important-to-know-for-copper?srsltid=AfmBOop3JtnfeHL4mOt3h7rgzUIo494fzgiwFHWDnPWJmjPmR-EifRER-EifRER But they of course aren't unbiased on the issue. Reactions: mat200 and johnfitz
