Relationship of Motion Trigger, AI, and Alert
Pyrofighting
Oct 16, 2017
67
26
I have been using BI for eight years. Had notifications mostly dialed in before AI. Started using Code Project about two years ago and really got it perfected preventing alerts from cats, coyotes, etc.
I have updated to Version 6 and now going to use the built-in AI models. My issue is remembering the relationship between Motion/ Trigger, AI, and Alert. I remember there being a change around 5.8/ 5.9 but can’t remember.
Am I correct saying:
1. In Motion/ Trigger, using When Triggered->On Trigger to send push notification, that push notification ONLY uses the basic settings in “Motion Sensor” to activate or not.
2. In Alert using Actions-> On Alert to send push notification, that push notification uses AI to decide to send a notification or not. Example: If I have AI->Use of AI-Confirm alerts->Set to Cancel with bird, cat, dog the alert will not send. If I have AI->Use of AI-Confirm alerts->Set to Confirm with car, person, bike the alert will send.
3. To dumb it down… The main purpose of Motion/Trigger is to set the parameters of a trigger for Record. I should use Alert in conjunction with AI to have better alerting/ push notifications.
