Red light slow flash - Network exception in EZVIZ HB8
Aug 10, 2025
2
Argentina
After accepting the recomended update over the existing version of V5.3.6 build 240522, my EZVIZ HB8 stop accesing any network. By the documentation, it has its 32 Gb internally as a eMMC memory onboard, can't be replaced.
I've tried:
  • soft reset/ hard reset
  • pluging the USB cable to a notebook (it doesn't detect the camera as a USB drive :-( )
  • adding the camera using the phone App and the Windows App (EZVIZ STudio, all options, even LAN devices searching).
The AP mode never exposes it's network (SSID = EZVIZ_J9344xxxx ). The red light flashes slowly some minutes, then some seconds appears a blue light (in that moment, the SSID doesn't appears).
Is there a way to reset the firmware to the previous version or to any working version, like the fabric default version?
Thank you in advance.
