M MicahJames Pulling my weight Aug 26, 2019 189 213 San Jose, ca Aug 1, 2022 #1 Does anyone know what setting I should check first to figure out what’s causing these green flashes? View attachment trim.9C8435CA-B372-41FB-AB8F-710C04C4EFBE.MOV
wittaj IPCT Contributor Apr 28, 2019 30,862 59,226 USA Aug 1, 2022 #2 Are you running hardware acceleration? If so turn it off. Are you running any codec in the camera like +? Use just H264. Reactions: JDreaming
M MicahJames Pulling my weight Aug 26, 2019 189 213 San Jose, ca Aug 2, 2022 #3 wittaj said: Are you running hardware acceleration? If so turn it off. Are you running any codec in the camera like +? Use just H264. Click to expand... i don’t know how you do it but you always end up helping me and it always works. I’m very grateful. I turned off hardware decode and that appeared to have done the trick. Thanks a million Attachments IMG_3160.MOV IMG_3160.MOV 5.5 MB Reactions: JDreaming
