Hi, I had a network down incident yesterday. One of my cameras continued to record events to it's SD card (2CD2135F-I) which was great, and exactly what I wanted. The other camera (2CD2732F-IS) which is configured for continuos record failed to record anything to it's SD card for the 20 or so minuted that the lan was disconnected. I checked the SD card and it's status was normal. I reformatted it anyway, but it didn't make any difference. I just wondered if anyone had any ideas in terms of how to troubleshoot this problem?
Does it need any extra configuration to get this to work? (I don't remember doing any for my other camera apart from inserting, formatting and initialising the SD card). Also, could it be that fact that this particular cam is set to record continuously? The problematic camera is running v5.25 FW.
Any advice or suggestions will be much appreciated.
Cheers.
Cheers.
