What do you mean by it is recording every 30 minutes? Do you mean you have the clips set to 30 minutes?
The setting your showing us isn't controlling the recording functions.
thats on another tab in settings
Do you mean go into BI and sync the app to DHCP?But you have to go into your BI app and sync it if your going that way....
I’ve seen that selection before but my issue is not the length of clip but BI appears to record every 30 minutes regardless of triggers, if any. At least that’s what I observed. I may be wrong. I’ll recheck in a few days.Record length is set in each cameras record tab like in this photo.View attachment 142342
I’ve not gotten to that level yet. Nor email notifications. I’m such a noob.whatever changes happen to that Webserver when it refreshes the IP address....would have to also be changed in the BI Mobile App. Namely the Ipaddress where your phone will now find the BI server.
You are right. I believe BI will delete based on my settings. I’ll refrain in the future.You should not have to delete any clips if you have your storage space set under setup, Clips and Storage tab.
Not sure what you mean here...records nothing? Are you saying that there are alerts for each cam every 30 minutes? If so, that could be taking a JPG shot every 30 min. That is on the Record tab of the cam settings.BI seems to record nothing every 30 minutes.
Or are you saying that every 30 minutes there are video files that have no size? Nothing on them?
Are you recording continuous or just on triggers?
