Hi
What's the recommended recording / backup settings?
Basically I have 2 cameras recording 24/7 (1280 x 720 at 15fps) and 2 cameras only on motion.. Running on NUC.. The main dump is on D:\ which has 150GB (set 100GB for Blue Iris) and once that is filling up transfer it to my NAS with 450GB capacity.
Previously I had set it to convert to MP4 when transferring from D:\ to NAS which I think was basically running the NUC on 100% due to conversion perhaps.
But now i have turned if off.. But I am guessing it will not store long history due to file size? What size would i get for the above setting?
What would I get out of this setup and what is the recommendation? My goal is to if possible not task the NUC to hard and try to store a history as long as possible (30 days or 15 days but can compromise on that) with decent quality just in case if i ever need to use it legally
