Recorded files dimensions H264
skiocink
Mar 20, 2018
53
8
Hi to all,
after the 1st September update, my recorded files (bvr files cmpressed without audio and standard settings) over tripled their dimensions. Now my BI is upgraded to latest version but the issue is still present.
The only way to reduce dimensions is change, in Encoder Options, the Rate Control setting a Max Bitrate. To produce files with dimensions similar to "the previous situation" I have to set a Max Bitrate to 512 or lower, but i NEVER before touched this settings
Nothing is changed in camera settings (Arecont AV12186). so something goes wrong in BI.
HP Elitedesk G2 mini
i7-6700
16GB Ram
nvme disk 512
ssd 512gb
Hi to all,
i7-6700
16GB Ram
nvme disk 512
ssd 512gb
You should be recording direct to disc... The only thing that affects the file size there is the bitrate...
The bitrate values in camera settings are unchanged. Also the status window in blue iris reports the same bitrate values that I seen from first day.
From 1st September something works bad in the compression algorythm.
I have not cpu or ram issues (5%-170mb). Direct to disk will produce biggest files and I have not enough space
You are mistaken direct to disc does not create the biggest files you just have to adjust the bitrate on the camera accordingly... Right now you are having blueiris re encode the Stream ...
