Hello,
Here is my current setup as a business user.
BI does record during the Work Hours. It seems to creates two files for each camera while recording is taking place.
Is one for substream and one for main stream?
Is the most recent substream one deleted when the next set of files starts recording?
- 35 Reolink 5MP cameras on ethernet network
- Direct to disk recording
- Two profiles : (1) Off Hours (each camera set to record when triggered on motion sensor using default configuration) (2) Work Hours (each camera set to record continuous to triggers)
- Dedicated server with 54TB RAID-5 array set to use 50,000GB, set to Delete, not limiting clips by age
- CPU 8%, disk active time 1-3%, memory 9%
