Trying to figure out what additional hardware, if any, if I'll need to re-connect 6 cameras on this property.
Core Hardware is:
(NVR): LTS LTN8932
(Switch): LTS POE-SW1602
(Cams): LTS CMIP9142W
This is a church campus where they bulldozed the center building which was the network "hub," where the camera system was housed. Previously, all cams connected directly to the POE Switch that uplinks to the NVR. Then 4 buildings became 3, fiber now connects the buildings. NVR & POE switch are now in a building at one "end of the line." I want to re-connect 6 cameras, all of which are no longer in reach of direct-connect to the NVR/POE switch. The fiber links feed Netgear/TP-Link/Dell switches in each of the buildings, yes a bit of a hodge/podge but it's good stuff and it simply works. Current network is flat, no VLANS.
The active cameras are on a 192.0.0.0 subnet. LAN subnet is 10.10.1.0. My question is, can I re-program the cams I want to re-connect with 10.10.1.x IPs and have them work? Or is a VLAN an absolute requirement. I think the VLAN approach is probably best, but it adds cost which they are sensitive to after the remodel project. I downloaded & read the manual for the NVR but I can't find any info that addresses this, it seems to assume you're going to use the 192 addresses & that's the end of it.
Follow-up question: We're adding a new cam that we still need to buy. Since everything is LTS, I figured I'd buy one more of those. 2 of the existing CMIP9142Ws I plan to mount on the side of a building across a small field from 2 doors that are about 75' away or so. Or I could take one of those and point it at another door that needs coverage, the mount point is much closer in that location, maybe 20 feet. Then the new cam could be a better model for the 75' shot? Just trying to think it through, use what we have, and maybe improve the end result...
Thanks for any help!
Core Hardware is:
(NVR): LTS LTN8932
