- Dec 21, 2017
- 1,288
- 1,201
Hi folks,
Is there a convenient power supply from Amazon or the like to use with Hikvision cameras for purposes of configuration ?
In normal operation they will get POE from the NVR, but if I want to plug a cam into a laptop to poke around in its settings, I need to give them I think 12 V. I don't have a stand alone POE switch.
So either a stand alone supply with correct plug to mate the power connector or a pass through power injector for the network line would do.
What do you use? Several injectors are on Amazon but want a tried and true solution. Thanks!
Marc
PS my cam auto configured fine with the Hikvision NVR but thinking about adjusting some things directly.
Sent from my ONEPLUS A3000 using Tapatalk
Marc
