Just wondering what everyone is using on bigger installs, most threads are on the smaller 4-8 port switches and I was wondering what people had good success with on the larger end of the spectrum without breaking the bank.
My default switch currently is a Zyxel 16 port switch, the ES1100-16P with 8 poe and 8 standard ports. I have need of all 8 poe ports and usually use 4-6 of the standard ports for the some of the other equipment I use in the install area. These switches are working pretty well, the only failures have been lightning related and then usually it is only a port or three that die and not the entire switch which is nice. On some locations now I have need of more ports, and while I can just use two or three of the Zyxel switches I'd prefer a more elegant solution.
I'm also using fiber to connect longer distances to secondary switch points too, so SFP ports could be nice to be directly integrated and not use an adapter. I have great switches I know would work perfectly just not at a price that makes me happy for camera use! Wondering where the reliable bargains are for 16-24 port switches with or without SFP in them and figured we could share the info if anyone has insight. No management needed in my case, though most will be I suspect.
