HI, I currently have a very old RCA HSDB1 that's still kicking, but I think it's time for an upgrade. I'm recording it with a Laview NVR, which is also pretty old and only capable of 1080p.
The condo has CAT5 outlets in various places, but unfortunately none outside and none really near a place where I'd be able to get to the doorbell area, so I won't able to get the POE version of Reolink (it would have to be the WIFI version.)
Reading around, it seems like the Reolink doorbell cam is one of the best at this time. I want to have 24/7 recording, so I am trying to figure out which NVR I should get, because I'd also like to get a couple cameras on the outside. I tried out a couple free programs (Scrypted and Frigate and had various issues, such as video lag, etc.)
Going back to the POE issue, I have a central hub where all the CAT5 wires feed into, so I was thinking of possibly using one of the closest CAT5 outlets to feed a camera a the front of the place. The problem is, I don't really want to drill holes, so I was thinking it might be possible to using this to get through the window:
Considering all of the above, what NVR/camera system would you recommend? Can CAT5 even run POE?
Thanks
Thanks
