I currently have an old Foscam clone hanging in an aftermarket dome attached to my house. It works Ok, but would like to get an upgrade. Specifically, better resolution (2MP?), and better low light performance. It needs to be in a glass dome (I don't want to make it easy for someone to see here it's pointed), which likely means IR isn't a good idea. The area is somewhat lit, so that shouldn't be an issue.
I'm looking to replace the whole housing with a plug-and-play outdoor network camera. I've seen them in the $100 range on Ebay, but further investigation leads me to believe they won't be much of an upgrade. I can push my budget to $200, but not much more. Any suggestions:
Requirements:
Doesn't have to be rebooted every day
Wired
Pan/Tilt (Optical Zoom would be nice, but not absolutely required)
Weatherproof
Low Light
Domed
Audio would be nice, but not needed
Thanks!
Requirements:
Wired
Weatherproof
Low Light
Domed
Thanks!
