Hello,
I'm new to the forum! I'm looking for a recommendation on which Hikvision NVR to get. My current system is 16 cameras that are all OEM or retail box Hikvision. Most are 3 mp and a couple 4 mp. Some are PTZ. My current NVR is a Nuuo Titan. I'm thinking of switching to a Hikvision NVR because some of the cameras are not totally supported by the Nuuo. And since all my cameras are Hikvision it may be easier to get them set up in a Hikvision NVR. I have looked at the value line NVR's but only the best one has enough bandwidth input for my camera setup, and it's close. I think I'll be happier with a Pro Series NVR that has some capacity to spare. I want it to run as smooth as possible. I mostly watch video and download off site using a 100 mb per second connection so I know my limitation there. At least on the recording side of things I want it to record smoothly. I have a 32 channel POE switch so don't necessarily need a POE NVR. Any Hikvision experts out there with some suggestions?
