Recommend me a camera that can zoom
perfect777
Mar 18, 2020
57
16
KC
School has started and the district has moved the bus stop from directly in front of my house to about 100-150 yards away. I have a camera (Loryta IPC-T541IR-AS 6MM) aimed in that direction, but my kids are just a few pixels and my wife has given me the green light to get a better camera to address the issue.
My primary goal is for a camera that has a good zoom that can see this circled area better:
My secondary goal would be a camera that can actually programmatically zoom at select times (during bus pick up / drop off), but act as a regular non-zoom the remainder of the time. It is nice getting a view of the whole street - but we only need the bus stop zoomed in view for a few minutes AM/PM. Does something like this exist?
Ideally it would be a PTZ, but you could use the Z12E that many use for plates, but it isn't good to constantly zoom a varifocal.
This PTZ would work well as long as they are not out in the dark as the IR reach isn't very far
And then the Z12E
Personally I would go with the PTZ to give you more options.
PTZ might be what you want.
A larger PTZ should work .. good thing for WAF pre-approval
The problem I see is that area is not in the center of your current view. If all the camera can do is zoom, then you'd need the zoomed in and zoomed out views to have the same center.
So a PTZ instead?
Sorry - not sure that I follow?
A camera that only can zoom is always centered on the middle of the view. In your case you want that to be the bus stop which is up and to the left.
If you zoomed the view pictured, you'd be looking at your immediate neighbor's mailbox and driveway.
If you moved the camera so it was centered on the bus stop, when you zoomed out you'd be looking at more sky and less road.
So you either have to give up the idea of the camera doing double duty, or you'd want a camera that can also pan and tilt so it could focus on the bus stop, hence a PTZ recommendation.
