- Jan 3, 2016
- 262
- 33
I'm finding many occasions where I would like to place a camera temporarily, so I'd like to find a generic wifi camera that I can use with my existing LTS (Hikvision OEM) NVR.
Edit to add notes on candidates:
- 1080p wide-angle would be fine, it doesn't need tons of megapixels.
- It should have good IR illumination built in.
- It should support ONVIF or otherwise work with a Hikvision style NVR.
- It should have some kind of stand that makes it easy move around and aim at whatever I need to monitor.
- It does not need to support any kind of smart motion sensing.
- It does not need PTZ though if it has it, great.
- Reolink 3MP PTZ with IR. $36 at Amazon. Seems to support ONVIF and the manufacturer even has help files for integrating with Blue Iris, Tiny Cam.
- Amcrest 2MP PTZ with IR and autotrack. $44 at Amazon. Mentions Sony sensor and low-light quality. This is the winner, good camera.
- Amcrest 2MP with IR and autotrack. $43 at Amazon. Does not make special mention of low light quality but has "AI" features.
