I plan to mount multiple LED floods st soffit height of a two story building and want all the floods to come on at the same time. Means I need to wire them all into the same PIR sensor.
The plan is to get one but mount it about 10ft off the ground with the lights about another 10ft above that (so preferably one where I can disable the photocell if there is one - I have a photocell mounted on the roof of the house while will be used to control when the sensor will be enabled).
Any recommendations for an outdoor (IP rated) PIR sensor?
