First, let me start with I have done someprelim research and read, but the more I read the more confused I get.
The web site recommends Nvidia and here Isee a lot of HD4000 or higher. So exactly what is needed to do hardwareencoding? QuickSync? CUDA? OpenGL
I was testing BI using a Gigabyte Brixmachine with an AMD A8 5557, and of course this means that I can’t use HA.
I will connect 28 D-Link DCS-6010L cameraswhich are 2M
http://www.dlink.com/uk/en/support/product/dcs-6010l-2-megapixel-panoramic-wireless-cloud-camera
Unfortunatelythe cloud feature does not work very well with this many cameras (it is a painto switch, and the cameras have problem holding the session to the cloud, butthey are running fine locally)
So, 28 camerasis a lot, and we might add a few more. Can I do all of these from 1 system?
In the futurewe might also start switching cameras to something a bit more professional aswell.
These camerasare located in remote locations (1 or 2 per location) and the locations areconnected thru a VPN hub back to where I will have the DVR running
I think ideallyI would preffer a rack mounted machine, or something that does not take muchspace.
I though theBrix was going to be a winner for this, but I guess not
I also have aNUC with a Core i5-5250U CPU but the passmark score is not that much better (Ispassmark score super important here?)
In contrast anolder 4770K is 3 times the score.
Considering theamount of cameras we will have I am not looking for a cheap system. I don’twant to skimp, but also not the most expensive system would necessarily help.
For example,some Xeon have integrated graphics, like the E3-1285 v3 have Intel® HD GraphicsP4700. Will that enable HA? I am guessing yes.
As I wasreading I realized that this unit might have been a better test
http://www.newegg.com/Product/Product.aspx?Item=N82E16856164011
I actually haveone, but I am using it as my SteamBox (The iRis Pro are decent)
I am a bitconfused and undecided with so many roads.
I guess tostart I will have to find a CPU to handle 30+ cameras. Also as I am readying,no low power CPU options, right? Does Nvidia card make a difference?
Also, I amguessing HT (Hyper Threading) helps, so a Core i7 can be fully utilized. Iusually don’t look much at them because they are overpowered for mostactivities, but for this it will help.
Looking atSkydale that leaves me with the Core i7-6700 (or the Core i5-6600)
My currentsystem has a 4770K. Should I use this as the BI server? (and use this an excuseto move my main system to Skydale J?)
My problemright now is that I don’t know how much of a difference does the HD graphics,and if I will need more than 1 system
