Outside of the pole being owned by the property owner or having an agreement with whoever.
I agree. I think the owner just rolled the dice on it. I was sceptical about doing it and installed accordingly. a flat screw driver and some wire cutters to uninstall. And beers
I’ve seen a lot of iffy installs that actually stole power from the pole!
For sure, the camera was a 5241E-Z12E and was installed at about 11 ft high. We connected the camera to a Poe switch, and also used a 4 ch NVR to record. The owner wanted to capture license plates I believe. I left the set up to him, as he is abit of a enthusiast and Im not a expert when comes to this lpr stuff. Yet. The position of the camera was suggested by owner and in A great spot (IMO) for a head on shot of cars coming or leaving the street.I’d love to read more details about the installation and hardware in place. Such as the height used and why. What the owner was intending to capture such as license plates etc.
Along with how you trenched the conduit. Did you actually go under the public sidewalk?
Regardless, the installation on the pole was top shelf!I’ve seen a lot of iffy installs that actually stole power from the pole!
As for wiring I used gel filled direct burial cat5e and edged it in 6” deep along laneway/sidewalk . I got lucky crossing the sidewalk with there being a 1/2” gap between slabs that was filled with dirt . Scraped out the dirt, tucked wire in 2” deep, filled in with dirt again . Other alternative was to take my 6’ dull 3/4” installers oger flex bit and tunnel across, just underneath the slab which is approx (5-6”) thick.
A number of years back we had to run 500 feet of fibre cable to a sub station. There was a cement pad we had to go through and not just expecting it to be thicker than 4-8”.
