Hammerhead786
Pulling my weight
- Apr 23, 2018
- 250
- 165
Just to add my 2 cents worth regarding the Procurve 2620. I found the web gui a little poor on the usability/configuration side of things. There is a text based utility which makes things a little easier, but most of the configuration requires use of the command line. In terms of noise, I've not found it to be excessively loud. My switch lives in the laundry room next to the kitchen and I can't hear it at all when the laundry room door is closed.
