Hello,
The posts here and here show scripts that can log into and execute commands in the top-201 cameras. One triggers a motion alarm and the other takes a snapshot.
Does anyone have a script that will reboot these cameras? Mine are branded ELP, but appear to be identical, even the stream path is the same.
The maintenance function built into the camera cannot be trusted, as the cams never actually know what time it is after a day or two. Not sure why that is.
The goal here is to create a .bat file or something, then set a Windows scheduled task to run the file regularly.
Thanks,
0 k
Thanks,
0 k
