You should not need to restart the software on a daily basis if you do something is very wrong and that issue should be addressed rather than putting a Band-Aid on it
Thanks for replyYou can always use Windows Scheduler if you want to force windows to reboot BI.
You need to perform a clean install of windows using MS media creation tool and dont run other crap on the system. You will not have these problems.Thanks for reply
I have sent to BI help desk an inquiry concerning troubles I have been experiencing since some months: BI crashes without notice every 3/4 days
I have uninstalled and installed again BI but the problem remains.
They also tried to solve but they didn't find a solution
Only chance I have thought about is to reboot program automatically every day
I have tried some programs like auto shut down and Automate but they don't work properly
Do you have any ideas ?
Thanks in advance
Cargo
Ok thanks a lotYou need to perform a clean install of windows using MS media creation tool and dont run other crap on the system. You will not have these problems.
Thanks for reply
I have tried task scheduler in windows but I have noticed it is not possible to close it automatically and the re-open again
Thanks in advance
Cargo
sumtips.com
