Hi
I have a few Hikvision cameras and the last one is a $200 PTZ that is only available with 5.3.0 Chinese version.
Since the menues are almost equal to the other english cameras, I have no problem setting it up.
Adding it to the ezviz cloud is easy with a DNS setting in my router and local access and setup may also be done with Onvif software.
If I understand correctly it is a problem with a Hikvision NVR, since it will only accept cameras with the same language as itself.
Are there any other reasons for not buying a chinese version?
I really like the PTZ camera and am wondering if I should buy another
Thank you
Thank you
