I wanted a outdoor wall mount for an Amcrest IP8M-T2599EW turret camera... thats this camera,
store.ipcamtalk.com
ok, not realizing these things aren't interchangable, I bought a bracket that I thought was the right thing, and its a very nicely made mount, but its for a smaller camera with a 110mm OD and 4 screws on a 100mm circle, or 3 or 4 screws on a 85mm circle. Well, the amcrest IP8M-T2599EW is 123mm OD, and has 4 screws on a 70mm circle. arrrrrgh.
So I ordered a Amcrest AMCPFB203W mount,
amcrest.com
which specifically says its compatible with the IP8M-T2599EW and yes, its the right 110mm OD, but..... IT DOESN"T HAVE FOUR SCREW HOLES ON THE 70mm CIRCLE, wtf. it has 3 sets of 3 holes, all on larger circles, like 84mm, 98mm, 110mm.
this has been an exercise in frustration.
Amcrest UltraHD 4K (8MP) Outdoor Security IP Turret PoE Camera, 3840x2160, 98ft NightVision, 2.8mm Lens, IP67 Weatherproof, MicroSD Recording (256GB), White - IP Cam Talk Store
Stunning 4K ultra-high resolution Amcrest IP Camera w/ a 2.8mm lens. Includes all necessary hardware and more. Buy with confidence from IPCamTalk!
store.ipcamtalk.com
Amcrest Wall Mount Bracker for Dome Cameras AMCPFB203W
This Wall Mount Bracket is designed for Amcrest Dome Cameras. Package Includes: AMCPFB203W Wall Mount Bracket 4 x ST4 Screws 4 x Plastic Anchors 3 x M4 Screws 1 x Allen Wrench Compatible with: IPM-751B/W IP2M-851B/W IP2M-851EB/W IP2M-856EW IP3M-956B/W IP3M-956EB/W IP4M-1028B/EW...
