Ok, so it is not like I've not setup 400 or so of these cameras now so I feel I know my way around pretty well. Yet here I sit stumped and ready to severely injure some Hik 3032 cameras......
I am installing 24 Hik cameras in both bullets and domes right now at a new site. I have about 16 wired up and I'm waiting on construction on the rest. 9 worked perfectly normal, no issues. 7 of these will not take an IP to save my life. All connected to the same switch, tried using the server there setting IPs remotely and when I had trouble I grabbed my laptop that I've setup tons of cameras on in the past and tried there in person. No dice.
Every camera that will not tak an IP is running the same firmware, different than the rest. The firmware that is not working is 5.1.2 build 140904. This build I cannot get to do anything, if I can see them all and try to set an IP on one sadp will fail, then all of them will disappear for a while before I can see any of them with this build again. There rest work normally. My other cameras are on firmware 5.2 build 141107, and 5.1.2 build 140606. I tried updating cameras via TFTP but the bad build cameras will not respond at all, tftp server never does anything and acts like they are never plugged in. I upgraded two of the 5.1.2 build 140606 cameras via the same tftp just fine and they acted normal as I have come to expect.
These cameras are fresh out of the box, I have tried connecting to them directly to my laptop and a POE injector to upgrade and still they do not work. I CAN set an IP in sadp when directly connected to them, but after it is set they never show up again at all that I can tell. With any IP. These seem to have a bum build on them but I cannot get them to stinking upgrade to the 5.2 build!
I purchased these from @milkisbad so I'll contact them and see what they say too but for now I am just firing up each camera and if it has that firmware we can't install them. I have to go scrounge through all my stock and see how may of these have good vs bad firmware I guess! Any thoughts or ideas appreciated. Maybe there is a special TFTP version to use or something. I've tried a couple now, both work for other cameras but not this build.
