The place I rent used to have an alarm system and all it has left are a few motion sensors and the wall panel, could I re use these motions sensors any alarm system? Landlord doesn't want them.
Depends on the model of the sensor and the new system you will be using.... you can certainly reuse any wired contacts....was it a wired system? What system are you replacing it with?
Standard motion detectors use 4 wires. Two for power and two for the relay. The relay tells the alarm panel if there is motion or not. It does not send electrical signals or anything like that. It's a dry contact. I hate to be so blunt, but that is who I am and I will not change for anyone, and probably the reason I got banned from the other forum, but this is extremely basic burglar alarm knowledge. What are you gong to do when the hard stuff comes up? Is this your first alarm system project or do you have some experience?
Glad to hear about the skin. I tried not to be rude, but blunt is a good word, lol. Anyway, here is a good diagram to maybe help you understand. You doo not need the tamper unless your going for
overkill.
