Good evening,
I've been reading this forum for weeks now and have ended up with my entire nvr/camera system consisting of Dahua NVR w/PoE Cameras, and a managed PoE switch. As a fellow IT person, I followed the Network Engineers advice
My system is not installed outside just yet, but in test phase indoors.
To cover the basic entry points and smaller areas, I have some shorter distance specific:
2.8, 3.6, & 6mm
2 x HDW1320SP
2 x HDW4431C-A
2 x SD29204S-GN
Now I need to go further!
I'm trying to figure out a few things so i make the right decisions. I need a PTZ due to a crazy & criminal neighbor. Watching my 4x pointed at him the past 3 days, I've already seen some bad things. I am looking to get a cam with a zoom of at least 20x optical (my 4x doesn't quite have the zoom reach I need which is less than a football field).
Is this any good:
http://www.dahuasecurity.com/products/sd59220t-hn-1279.html
Does this have any sort of autotracking? If someone walks into my yard, can it follow them or zoom in on them? If not, what would you recommend?
Budget is a concern for me but I don't want to throw my money away on junk.
I'm also looking for a good 12mm 4mp day/night, but will never get real wet (maybe rain mist, if its lucky) or see sun in its location. Depending on price, a weather proof over 12mm.
All of my cameras have PoE on the connector but they also have an audio port. Is that for speakers that need to be powered?
I set up motion detection alarms and got a ton of emails from the wind blowing, I assume that's adjustable somewhere? Is there a good place to learn more detailed info about the alarm functions?
Thank you so much!
2.8, 3.6, & 6mm
2 x HDW1320SP
2 x HDW4431C-A
2 x SD29204S-GN
Is this any good:
Thank you so much!
